zero1niner said:I have had this happen twice now, so I am guessing that this may be a problem. Out of nowhere, driving down the road (not touching anything related to the radio) listening to the iPod, the mode changed to the FM stereo all by itself. I tried to switch back to the icelink, but it would not switch back. Ended up having to turn the radio off, waiting a minute, then turning it back on to get things working again.
LCC said:THis is a known problem. I hope they resolve it with the next firmware, it happens to me a lot as well.
zero1niner said:I know I asked this earlier, but the problem is starting to drive me a little nuts, and I am currious if anyone else is or has experienced this problem.
I noticed that every time a song changes, the next track seems to be glitching or compressing the very beginning of the song. Its very consistent too. Happens on each song change. Its a slight volume drop then back to normal.
Anyone else experiencing this??
02 330ci w/HK NAV
operknockity said:And have you followed Tom's request to e-mail him directly so he can work with you to try and diagnose what the problem is so they can work on a fix??????
zero1niner said:I did email him about it, but my question was if anyone else is having the problem.
operknockity said:Sorry, didn't mean to come off all huffy.
I'm sure if others were having the same problem, they'd have already chimed in (assuming they frequent the Audio/ICE forum, which is not a sure thing, and they read the original posting).
You might want to also check over at E46Fanatics, if you haven't already, as there have been quite a few long running threads on Icelink issues. Note that Tom reads those threads too, so if this had come up and there was already a fix, I'm sure he'd of said something to that effect.
Jackflash said:I am having the same identical problems..... :bawling: I emailed Tom last night.....
02 330ci w/HK NAV
16hr Day said:I installed mine yesterday and am having similar problems. it's like the is a clip at the beginning of a sond perhaps a compression issue. I also have it switching to FM for no reason but I am able to just switch right back. I emailed Tom, waiting for a response.
tayer said:Tom:
Identical problem here. Quick compressions at front end of all tunes, occassional unexpected cut out (back to FM).
Suggestions greatly appreciated.
Thx.
Tyler
