I was worried that my new 2022 M440 Gran Coupe (G26) had an air conditioner refrigerant leak already, or worse. It woudn't get cold enough to keep up with the summer heat unless I kept it on MAX, and even then it seemed too warm. But there was nothing wrong with the AC -- it was my setting, buried in the user settings for Vehicle Climate Control, for the warm air mixture pushed all the way to the red (right) side. (I had done that in mid-winter when I wanted AC to dry out the air and reduce inside fogging on the windows, but also wanted it to keep as warm as possible.)
After moving the indicator all the way to the cold side on the screen (or using the iDrive control knob), the AC blows much colder and works perfectly!
So if you have a weak air conditioner, first check this setting. On older models it was a knurled wheel on the dash between the middle vents, with blue dashed lines on one side and red on the other. Now it's buried in the Vehicle/Climate Control Settings submenus.
Thanks to my salesman Matt at BMW of Nashville for immediately suggesting this simple fix and saving me a lot of trouble.
