Status
Not open for further replies.
61 - 63 of 63 Posts
Oily intake
Kudos to LPCapital for this thread. I'm still trying to find time to order and install a Pro-vent or similar PCV oil separator. At 110K miles I've had to change MAP and now throttle servo unit. Had I (or BMW) installed a proper separator to begin with, it's unlikely either would have been necessary.
For overall information as you prepare to work on this, be aware that lpcapital/zetatre cross-posted this information at xoutpost. In particular, some modifications with regard to tubing/supplies/brake line routing are discussed starting at about post #20. The link is here: http://www.xoutpost.com/bmw-sav-for...av-forums/x5-e70-forum/97266-35d-adding-crankcase-breather-oil-separator-2.html
Just to add to your experience, I also had to replace my throttle servo motor (anti-shudder valve) due to carbon/oil build up, and changed my MAP sensor as pre-emptive maintenance.
Hope that helps. Good luck.
Stephen
Discussion starter · #63 ·
Stephen
So far none of the tubing I used have held up: they all get damaged more or less slowly by the oil.
I resorted to spend the money and bought the one from Patrick Motorsports that sgrice talks about on the xoutpost link. UPS will deliver them Friday.
Other than that the system continue to work extremely well. Any oil consumption i had before has entirely disappeared and there's essentially no oil deposited in the intake. Carbon on the EGR valve is a very thin coat and dry.
Sent from my Nexus 7 using Tapatalk
61 - 63 of 63 Posts
Status
You have insufficient privileges to reply here.
