I'm having my '08 535xi DME programmed. It halted when the tranfer case module failed to respond. It's the unit under the passenger seat. I understand that the auto transmission module is in the transmission case.
When I ran the Bavarian Technic tests the Gearbox Control Unit was ok. The part the dealer said was bad is part no. 27607567803 which is the transfer box control unit. I don't know if this is the same part or not. If my test said it was good and it didn't work at the dealership then maybe there was just some corrosion on the plug. It got some water on the floor and I cleaned the plug but maybe need to do it again. I opened the box and it was perfect, no water or corrosion. I just need to know if I need to buy a new unit or not ($700). I left the vehicle at the dealership so can't repeat the tests right now. Any help would be appreciated.
