So here is another issue, that i can not resolve. "Increased battery discharge" I have been getting message every time i start my car after few hours being sit. At the beginning i thought its a battery, but the battery was tested and is still OK. From what i noticed vehicle is going to sleep mode and after 15 seconds wakes up and so on for a few minutes and then go sleep until i open the door. Start/Stop button and gear switch green light is always on at that time. sometimes is takes about an hour for the vehicle to be in a sleep mode and start/stop bottom light be off. I run fault test on ISTA-D (no fault errors stored) also run "Wake-up" analysis (Attached photos). Report says the vehicle was woken up too many times, at the same time intervals at the same km. Also photo of the Battery Charge Stage. Clearly vehicle can not go to sleep mode at the first try, something keeps the vehicle to wake up again. I have tried that with car locked and unlocked - Same results.
Can anyone help?
Can anyone help?
