Hello I’m new to the forums here and I just picked up an f10 535i and it needs some love. Trying to figure out what could be causing such a list of codes and figured I would ask the forums sooner than later as I don’t have much background in f series electrical work. From what I understand it has a new battery and MAP sensor and it is throwing a drivetrain limp mode error on the dash and has absolutely no torque and barely goes a few mile an hour. At idle the engine sounds good and even revving in park seems to be normal. Any help would be much appreciated!
- DME active codes -
102A01 - Hot film air mass meter, signal: Electrical fault.
103002 - Accelerator pedal module, pedal-travel sensor 1, electrical: Short circuit to ground.
104402 - Absolute pressure sensor, intake pipe, electrical: Short circuit to ground.
119002 - Rail pressure sensor, electrical: Short circuit to ground.
119202 - Fuel low-pressure sensor, electrical: Short circuit to ground.
120408 - Charging pressure control: Switch-off as consequential reaction.
121002 - Boost pressure sensor, electrical: Short circuit to ground.
135608 - Valvetronic system: No movement identified.
135808 - Valvetronic servomotor, position sensors, electrical: Malfunction.
135908 - Valvetronic servomotor, position sensors: Supply voltage missing.
135C11 - Valvetronic servomotor, position sensors: Signals implausible.
1F1A90 - DME, monitoring, 5 V sensor supply: Voltage outside valid range.
213604 - Power management: Standby current violation.
213901 - Power management: Reduction or shutdown of individual power consumer.
215701 - Intelligent battery sensor (IBS) defective.
218404 - Start voltage transformer, activation: Line disconnection.
- DME shadow (inactive) codes -
10351C - Accelerator pedal module, pedal-travel sensor Multiple fault.
11B401 - Fuel high pressure or after enabling injection (2nd ambient condition set after delay): Pressure too low.
1FB101 - Check Control message (ID 229): Vehicle battery charge low!.
- Transmission active codes -
CF16D1 - Message (group fault 3 - effect on driving: none): receiver EGS, transmitter DSC .
CF2301 - No message (status, safety belt contact, seat occupancy, 0x297), receiver EGS, transmitter ACSM .
CF2CE1 - Signal (actual accelerator pedal angle - signals a bad quality use signal, 0xD9) implausible, transmitter DME/DDE .
