21 - 40 of 2963 Posts
I got the link and downloaded. My question is I have had a working inpa on my system before downloading this one. Is there a way to just copy some files into my current install or do I need to uninstall and reinstall this setup? Sorry for being such a noob.
Premium Member
What is in your current INPA that is not in the new one?
In any event, you can merge the two EDIABAS folders, and then just keep your old INPA folder and have this as a second INPA_Fxx folder, and you can run both INPA versions.
inpa version is 5.0
I have no idea how to merge them.
I have a f10 I need to clear some airbag codes. It had a deployed head rest and seat belt tensioners where blown no air back deployment. I replaced/repaired now I need to reset. I read I could use ncs expert and load f01 but that isnt a choice. When I run my current inpa f01 is a choice but I get error can find f01.eng
Premium Member
inpa version is 5.0
Copy new EDIABS folder on top of old EDIBAS folder, and overide any of the old files.
You cannot use NCS Expert on Fxx chassis, it is for Exx chassis only.
Use Tool32 to clear your fault codes:
Clear Fault Codes:
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
Premium Member
Shawn thanks again. I did what you suggested and this is what I got.
EDIABAS Fehler 28 : IFH-0018: INITIALIZATION ERROR
Are you connected to the car, car powered up, and EDIABAS set for ENET interface?
Premium Member
Ok I think I know what the problem is but do not know how to fix it. I had the serial cable now i have the usb cable. How do I change my settings so my new usb cable can communicate?
Is this for your F10 550i Chassis?
yes K+dcan usb interface is the cable I have now is this the wrong cable?
If I remember correctly my old cable for my 2011 328i was a serial cable. I ordered the usb K+dcan for the f10/
OOPS I got it wrong this is the old cable the usb to k+dcan.
I ordered the enet cable for the f10 and now I can't find it.
Premium Member
Yes, it is the wrong interface cable. All Fxx chassis like your 2011 F10 require an ENET interface cable for use with all Apps using EDIABAS (e.g. Tool32, INPA, E-Sys, etc.). This is an Ethernet by OBDII connection.
Exx chassis like your 2011 328i require a K+DCAN interface. This is an USB by OBDII connection.
Premium Member
Thinks a lot Shawn!
When i coding with a E90 today.Error messagse like "COAPI-2021: data transmission to ECU disturbed. IFH-0010: DATATRANSMISSION TO CONTROLUNIT DISTURBED"!
Anybody know why?
My daten file if 49.0,and I have been programmed E90 Successfully before.
