41 - 60 of 2963 Posts
Yes, INPA works with Fxx Chassis, so long as you have the Fxx .IPO files installed.
It will use whatever interface you have defined in EDIABAS.ini, so ENET is fine.
Here is my INPA 5.06 with Fxx Scripts:
Hi,
I am searching for the inpa scripts and ipo files for the f series.
can you send me a link, too?
best regards
Premium Member
Hi Shawn,
this is my first post after presemtation.
May I have the link for INPA and scripts?
My car is an F11 525D produced in November 2011 (4 cyl, twin turbo).
Thanks for your support to all of us necwcomers.
P.S.
I have already succesfully used E-sys for coding and tool32 for errors canceling.
Regards from Italy.
Bruno
Premium Member
Hi Shawn,
P.S.
Regards from Italy.
Bruno
PM sent.
Premium Member
Thank you Shawn,
downloaded and ready to install!
Just one question: should I put the INPA folder in C:\EC-Apps\ESG?
Or somewhere else?
Ciao
Yes. I have it alongside my original, so it is C:\EC-Apps\INPA_Fxx.
Premium Member
I got the link and downloaded. My question is I have had a working inpa on my system before downloading this one. Is there a way to just copy some files into my current install or do I need to uninstall and reinstall this setup? Sorry for being such a noob.
You can put INPA_Fxx folder alongside the existing INPA folder and run either or. The EDIABAS folder needs to be merged with your existing one.
My situation is a bit different.
I don't have any original INPA installed.
I have only E-sys.
Should I remove my installation and make a new one with E-sys and INPA?
In this case is there a link for a complete installer?
Or it is enough to copy the INPA fXX and merge the EDIABA folder?
Sorry for my dumb question.
Premium Member
I have only E-sys.
Just Copy INPA_Fxx to C:\EC-Apps\INPA_Fxx, and replace your EDIABAS folder with the included one.
Premium Member
Can i also have the f01 Inpa scripts (maybe also the link to the right inpa -i am not sure, if my inpa is outdated) please.
@Shawn you are doing such a great job for this forum and the users! Thank you very much!
PM sent.
Premium Member
OHHHHHHH pleas pleas can i have it toooo with isid is all so slowly ---- Pleas PM me INpa fos F-series --- Is it IN GERMAN too ?????
PM sent.
Hi Swan,
sorry to seem confused, but there are details that aren't totally clear to me.
And I would avoid to make errors in setting up the stuff.
1) The downloaded archive is made by INPA_Fxx folder, that contains INPA and EDIABAS folders.
I suppose the INPA (and not the main INPA_Fxx) folder should be put in C:\EC-APPS\
Could you please confirm?
2) The EDIABAS folder contains (in \Bin) the EDIABAS.INI, that is set to STD.OBD for the Interface entry.
I supose that I have to edit it to ENET, in order to work in my F11.
Could you confirm also this point?
Thanks again
The Coder guy in N.Y
There is in Ediabas/hardware/configurator. Run that and on the drop down menu press ENET and enter(left) and Ediabas is configured for ENET cable. No need to physically do any changes to Ediabas.ini
Problem solved!
After some experiment I did realized that it is necessary to have some INPA version installed before making the modifications, otherwise the INPA for Fxx doesn't work.
In my case I never had any INPA installed before and therefore I got an error (some dll was missing)
Now everything works.
Thanks again to all.
