1 - 4 of 4 Posts
I need advice in whether to change this myself or take it to a mechanic. My inside front passenger door handle won't open the door. The outside handle still works fine. Once I've removed the screw on the door handle, I have no clue how the whole things comes off since it's attached to the grab bar too. Any ideas, HELP! :tsk:
You Can DIY. It is a cable that is broken. The cable is under ten bucks from the dealer. You need to remove the door panel to get to it. It is part number 12 in the diagram.
Discussion Starter · #3 ·
TY for the diagram & advice. Now I need some directions on taking off the door panel. I'm a novice at this, so, if anyone has any step by step directions and/or a diagram, it would be much appreciated.
I <3 my E34
id say just remember or mark everything you take off and put it back together ive learned the best way to learn is to do it yourself and you will be better off knowing for further problems
1 - 4 of 4 Posts
