1 - 4 of 4 Posts
AM ATTEMPTING TO INSTALL FRONT STRUTS. AND I AM WONDERING IF ANYONE WOULD KNOW WHETHER I WILL NEED THE SPECIAL TOOL EXTENTION THAT TEMPORARILY THREADS ONTO THE END OF THE SHOCK ABSORBER SHAFT TO MAKE DISASSEMBLY EASIER AND SAFER. ALSO HOW MUCH OIL DO YOU ADD TO THE TRUT HOUSING? THANK YOU :(
should be able to thread the three nuts onto their respective shafts (loosely) then install the bottom half back together no problems. It didn't require any special tools when i did my suspension.
As far as the oil goes, i filled it up (with the shock in the strut housing) untill i just barely saw the oil with the naked eye. Everything turned out perfectly, hope that helps. :D
Discussion Starter · #4 ·
thank you so much for your reply. this is my first time accessing this site and boy am I excited if this is the kind of fedback that one can expect. Iam really looking forward to restoring my 1990 325i convertible.
1 - 4 of 4 Posts
