1 - 7 of 7 Posts
I was changing coolant in my F32 N20 and replacing the (Micky Mouse Flange) and snapped a bolt. Will Easy Out the sheared bolt out of the block. But how in the hell does the bolt shear off. Pushed it in past the o ring then started tighting then snap. Are you kidding me!!
1037429
1037430
Ship Captain of the Ever Given
Tightening how? Was it previously overtightened or been out several times already? How’s the threads ( you won’t know until it’s out )?
Discussion Starter · #4 ·
The old ones, I don't know maybe I had it in at an angle :unsure:. I went to BMW today at lunch and picked up a couple of new ones. And then stopped by Harbor Freight for a cheap Easy Out setup. Will give it a go in an hour or so and post back on the outcome.
Discussion Starter · #5 ·
Ok I was able to easy out the snapped bolt. Threads were good. Did some filing of some damage to the flange (should have taken a pic) and put a drop of oil on the mating surfaces and it installed perfectly this time.
Always new bolts in parts that have extreme temperature oscillation several times a day.
1 - 7 of 7 Posts
