I used cn90's vacuum method to try to find my intake leak, and I have two main questions, hopefully somebody has done this and can help me.
I have a 2002 530i with about 145,6xx-ish miles on it. Did the VANOS gaskets last year, installed brand new plugs (just checked them again by removing and cleaning them before the vacuum test.)
I bought a mechanic's stethoscope from Harbor Freight for $3.99. It seems to work really well. I ended up testing it on all sorts of things around my house...fridge, computer, etc...
Anyways, I removed the filter box, sealed the shop vac to the MAF, taped up the tailpipe and let the shop vac rip. Here's what I noticed:
1) I hear almost nothing anywhere on the rubber intake boots.
2) The intake manifold has some slight hissing noise away from the engine, which gets louder as you move towards the engine side.
3) The distribution piece (thingy on top of the manifold that splits into six little tubes, that's what RealOEM calls it,) is fairly loud too.
4) But the loudest of all comes from the tube in the photo that the silver stethoscope probe is touching. It seems to connect to a splitter and goes to a tube that goes almost straight down, and a thinner insulated tube that runs back along the intake manifold. I tried, but can't disconnect the tube here, it's pretty tight in there for my fingers.
Question #1:
I'm just not sure what the source of the leak is, although I'm fairly certain it's the tube in the photo (#4)
Question #2:
And since I tend to overthink things,
Do you think the noise from the distribution piece (#3) is a separate issue. I'm confused on this as the airways are smaller, and I can't decide if it's air being pulled from the tube (#4) rushing at higher pressure due to the narrow diameter of the airways in the distribution piece, or separate leaks.
Any ideas?
Steve
The silver rod with the glare is the stethoscope probe.
Question #1:
Question #2:
Any ideas?
Steve
