You may simply have a short in the interior light circuit. With a door open, inspect each bulb and holder. You can check the power in and out of the GM with your meter. The WDS is difficult to share on this forum. The pinouts are below. Note the beginning shows the three connectors on the GM. The colors of the connector and how many pins follow the assigned wire harness number. Then it lists each one individually. You should try to get the WDS to work for yourself. You will need JAVA with an exception in the JAVA console for it to work. The exception has to read
http://www.bmw-planet.com .
WDS link.
http://www.bmw-planet.com/diagrams/release/en/index.htm
A1 General module
Plug connector overview
Number X-pin, colour Description
X253 26-pin, black Plug connector B General module
X254 20-pin, black Plug connector C General module
X332 26-pin, natural Plug connector A General module
Pin assignments at plug connector X253
Pin Type Description / Signal type Connection /
Measuring notes
1 Not used
2 A Front lid signal Front lid contact switch
3 Not used
4 Not used
5 E Signal, radio protection for passenger compartment Interior protection control unit
6 Not used
7 Not used
8 A Vehicle inclination signal Inclination sensor
9 Not used
10 A Rear lid open signal Rear lid unlocking switch
11 A Rear lid open signal Rear lid release switch (interior)
12 A Signal, anti-jamming system Jamming protection switch, rear left window
13 A Crash signal Airbag diagnostic module
14 Not used
15 E Wiper I activation Wiper relay I
16 E Wiper II activation Wiper relay II
17 E Headlight cleaner activation Headlight washer module
18 E Intensive wash activation Headlight washer module
19 E LED activation LED display DWA
20 E Vehicle inclination signal Inclination sensor
21 Not used
22 Not used
23 E Rear left wheel speed Integrated electronic control unit (IKE)
24 A Signal, anti-jamming system Jamming protection switch, rear right window
25 A Intermittent switching supply Windscreen wiper switch
26 M Ground Ground connector
Pin assignments at plug connector X254
Measuring notes
1 M Ground Ground connector
2 A Open window signal Power window motor, rear left
3 A Soft-close drive signal Motor drive for rear lid servo lock
4 E Voltage supply terminal 30 Fuse F23
5 A Open window signal Power window motor, rear right
6 A Lock signal ZV motor drives, rear doors/tank flap
7 A Increase contact pressure signal ADV motor
8 M Ground Ground point
9 A Servotronic activation Electrohydraulic converter of servotronic
10 E Voltage supply terminal 30 Fuse F6
11 A Servotronic activation Electrohydraulic converter of servotronic
12 A Close window signal Power window motor, rear left
13 A Central arrest signal ZV motor drives, rear doors
14 A Unlock signal ZV motor drives, rear doors/tank flap
15 A Close window signal Power window motor, rear right
16 A Reduce contact pressure signal ADV motor
17 A Horn signal Antitheft horn (DWA)
18 A Pump signal Washer pump
19 A Signal, switch off consumer load Connector, switch off consumer load
20 A Interior lights signal Connector, interior lights
Pin assignments at plug connector X332
Measuring notes
1 E Voltage supply terminal 30 Fuse F55
2 E Interior lights signal Interior/reading lamp, front
3 E Windscreen wash signal Windscreen wiper switch
4 E Windscreen wipe 2 signal Windscreen wiper switch
5 E Windscreen wipe 1 signal Windscreen wiper switch
6 E Door contact signal Rear RH door contact switch
7 E Door contact signal Rear left door contact switch
8 Not used
9 E Unlock signal Rear lid lock switch
10 A Intensive wash activation Headlight washer module
11 E Rear lid closed signal Rear lid switch
12 E/A K-bus signal line K-bus connector
13 E Central locking signal Remote control central locking
14 M Ground Ground connector
15 E Close window signal Rear left door power window switch
16 E Intensive wash signal Windscreen wiper switch
17 E Open window signal Rear right door power window switch
18 E Close window signal Rear right door power window switch
19 E Signal soft-close automatic unlock Motor drive for rear lid servo lock
20 E Signal, windscreen wipers in motion Wiper motor
21 E Signal, contact pressure control (ADV) operated ADV motor
22 E Locked signal Rear lid lock switch
23 E Voltage supply terminal R Fuse F41
24 E Close signal Central locking (ZV) switch
25 E/A P-bus signal line P-bus connector
26 E Open window signal Rear left door power window switch
