1 - 20 of 22 Posts
· Registered
I have a black Z3 with standard seats. The interior is tan, tan and more tan. The only thing black is the cupholder console between the seats. I think it's a lot of tan. I just ordered some M seats and plan to get them recovered. I'm thinking of covering them in tan with black inserts, and I plan to get them without the stitching across the middle. They'll have a finish like the black ones here: http://leatherseats.com/Z3_leather_kit.asp in the video. I think those seats belong to a forum member, and I like the way the stitching is done... much prefer the look to the stitching across the middle of the seats.
So, how do you think these will look in the tan interior? Tan with black centers, and I'll get extra leather to do the door inserts in the matching black. And, I'm thinking of a black leather armrest from LeatherZ. I did use the leatherseats dot com color configurator located here design.leatherseats.com to preview it and I think it looks good. Sorry, I can't post pics yet or I'd copy it and include it here.
All opinions welcome! Am I getting in too deep thinking I can pull off the door panels and recover the centers?
· Registered
It will look good
I had the tan tan tan interior, got tired of it after a couple of years. Had the canvas top changed under warranty from tan to black, then I got new black leather (smooth) door panels, changed the air vents to black, black LeatherZ armrest, black LeatherZ door arm rests, black kickpanels in foot wells, black door strips, black shift boot and e-brake boot, then kept going with black everything on the rear console surrounding the roll hoops. I ended up using vinyl paint on the subwoofer cover cause the part is so dang expensive. Then I got wet okole seat covers in black and gray. So now I have tan carpet, dash and rear center console.
haha in other words, go for it, the two colors look good together
· Registered
Discussion Starter · #4 ·
Yeah, if you have pics to share that would be great!
I have the black M seats on the way, but don't think it would look right with only black seats and everything else tan. So I will prob wait until I get the seat covers to install them. When it's done I'll post pics too.
· Registered
Pics black and tan
Excuse the dirty floor mats, it has been raining here off and on for the past few months.
also missing my airbag decal from passenger door...
The steering wheel, main vents, visors, and glovebox latch come stock as black, I just went farther:D
· Registered
Discussion Starter · #6 ·
I found a thread where someone dyed their seats in the exact pattern I'm considering. Now that I saw this dye job (blue to tan) I'm undecided if I should just dye or spring for new leather covers.
· Volvo guy
They dye jobs can wear real quick in harsh environments like convertibles.
To keep it on a real budget I would get some black Z3M seats and just worry about the door inserts.
Aside from the looks, anything is better than the stock Z3 seats.
· DROZ3
· Registered
Discussion Starter · #12 ·
A friend has done this several times on 3-series cars. He said it's not as hard as it may seem. I think I'm going to give it a shot. The panels are held on by melted plastic that will have to be cut off. I'm going to try cutting them off flat to remove the panel. To put it back on, I'll attempt to use a small screw into the plastic with a large fender washer to grip the panel. If that doesn't work, my friend says you can attach the panels using windshield adhesive. He claims this works far better than any other type of glue because it's more permanent. I've read that other adhesives can let go after a year or two because of heating and cooling of the panel and the glue. I would like to do it in a way that if I ever remove it again, it won't destroy the panel, so plan A is the screw and washer method. I'll take some pics to show how it goes. I'll probably give it a shot in a few weeks.
· Registered
I was thinking I'd have to remove the entire door panel but sounds like I can get away with just prying and cutting off the inserts. I'll likely remove the whole door panel anyway - was thinking of replacing the tweeters. Hilarious how one task leads to another.
· Registered
Discussion Starter · #14 ·
I wasn't clear. You do have to remove the panel. Once it's off, cut the plastic "heads" to remove the leather covered panel. I think you'd mess up the backing of the panel if you tried to pry it out and cut behind it.
· Registered
Discussion Starter · #18 · (Edited)
I completed the seat recover work. I think it came out great. The leatherseats.com covers are really nice. The leather quality is excellent. It's high quality auto grade leather, has a nice feel, good texture and fit well. There are a few more areas of bunching than I expected but it looks great anyway. I think I can work some of those out just by moving the leather around on the foam... Working it.
· Registered
Discussion Starter · #19 ·
I can only seem to upload one photo per post. Notice that I chose not to get the double stitching like the M style, but more plain like the sport seat style. These are M seats. I think it's more classy this way, a little less sporty. I think it fits the "tuxedo" image of this car.
· Registered
Discussion Starter · #20 ·
I finally finished the interior work. The seat covers took a bit of massaging and a few days in the sun, but the wrinkles came out for the most part. They look great now. This spring, I removed the door panels and covered the inserts with the same black leather that is on the seats. Recovering them wasn't as hard as I thought it could end up being, and I'm really happy with the outcome. I think it looks nicely tied together, without being too much on the two-tone theme. I may do one last thing, which is beige leather steering wheel tabs. Beyond that, I think it's easy to get carried away with too much two-tone.
1 - 20 of 22 Posts
