1 - 2 of 2 Posts
Z4JOEY
My 2007 Z4 3.0i has a misfire. If I pull over and restart the engine, it will run fine. I may go 30 miles to a destination running fine, then on the way home it will start running bad. A service engine soon light came on yesterday, so I made an appointment with my mechanic. Today I drove it all over and the light was out and it ran fine again. It should still retain the code correct? I'm hoping the mechanic can find out what the problem is. Any ideas?
The code should still be there (and code should tell you which cylinder is misfiring). Common culprits are bad coil, spark plug or injector (coil most likely). Quick check is to swap coils between the misfiring cylinder and one of the other known good ones. If the misfire moves to the other cylinder, you know that coil is bad.
1 - 2 of 2 Posts
