Makes sense. So you need 2 hydraulic jacks to do this, right?
1. Jack one side of the car up from the normal jack point.
2. Jack up the same side from frame rail. Can't use a jack stand here for support, right? Because, how are you going to remove it?
3. Remove the jack from the jack point and swap it with a jack stand
4. Remove the jack from frame rail
Does that make sense? Has anybody done it like this before?
For best stability, I do this to raise the front:
1. Jack up the front using a pair of scissor jacks using the normal jack points
2. Place a third jack under the frame rail, and raise it slightly
3. On the same side, replace jack under jack point with a stand
4. Remove jack supporting the frame rail
5. Repeat for the other side
To lower the car:
1. Place jack under frame rail and raise it slightly
2. Replace stand with jack
3. Remove jack under frame rail
4. Repeat for the other side
My method and the scissor jacks are a bit slow. But this approach works for me.
