1 - 14 of 14 Posts
I was doing some work on the underside of my 540 and while there a examined the steering linkage. I plan on replacing the steering link and the idler arm during the summer and I wanted to get a closer look. I know that the idler arm has a bushing that goes bad but I didn’t see any thing wearable on the pitman arm. Would it be necessary to replace it?
Owning a BMW is always interesting
Discussion Starter #3
I knew someone was going to say that. I even said that myself when I looked at it but I just wanted clarification, thanks
I had to replace the pitman arm on my 540i a couple months ago. I made a thread about it and the reason why.
Yea, it was pretty easy. When it's off, it is really easy to check play with the ball joints on the center link.
I think the wear I had was unusual and it was definitely difficult to find. If I didn't explain it very well on this site, I have more details on the "other" forum.
Discussion Starter #8
The only thing that worried me about replacing the pitman arm was when I was reading the Bentley manual. It said it had to be at a specific height or something like that. How did you fare out?
I replaced mine preventively at around 140k miles, along with the other steering linkage parts . But examining it recently at 295k miles, it all looks fine. I asked the shop that does most of my work and they said they only replace the bushing, that the arm rarely requires replacing.
Discussion Starter #10
Are you talking about the idler arm or the pitman arm because unless I’m wrong, I don’t think the pitman arm has a bushing
Good catch! My mistake, I was speaking of the idler arm!
1 - 14 of 14 Posts
