Well done. Fixing that s--- in 15 degree weather is brutal; good work.And to answer the original question - no it is not the end. Just took for a test drive. No leaks. All systems OK. Full oil. No leaks that I can tell. Does smell a lot like burning oil under the hood…
Really? Now you tell me?If you need to do a bleed, put the battery charger on the posts under the hood. You can use a 10 amp charger and leave it to trickle charge the battery for 24 hours after, to make sure that the battery is fully charged.
