1 - 5 of 5 Posts
2008 335i
Hoping someone can clarify these errors/issues a bit...car has 104k miles.
Car stalls, 'jumps' (when sitting at a light) RPMs will jump, at times, car will displays all these errors and then will not shift out of 3rd gear...so I have to pull over, turn the car off, wait 5 seconds or so, then start her up again.
The car going from Park to R or D, at times, is noisy, sometimes not.
Im hoping seliniod (all 6?) replacement and full service on the tranny to fix, I don't have a way to pull codes but check engine light is on, obviously.
Thanks in advance.
Chris
Discussion Starter #3
Honestly without the error codes it's like throwing darts - blindfolded. Invest in a K+DCAN cable ($20) and download the free software available around here - you'll then have a factory level diagnostic tool. Start by posting the error codes from the engine ECU (DME) and the tranny ECU (EGS)
Ordered. Ill start researching Software to use..
Discussion Starter #4 (Edited)
This issue is really bumming me out. Cable comes today, but no help with the Software to use. I see rheingold?
Upgrades I just performed last week: (all new)
-Radiator
-Power Steering pump with fluid flush and fill
-Front Shocks
-Valve Cover replacement with Gasket
-Spark Plugs
-Coilovers
-Charge Pipe (Cobb Tuning)
-Vacuum Lines (2) that run over the Valve Cover
-Break booster line (that receives the 2 lines from the canisters that run over the valve cover)
-Blow-By Vent Hose ES#19642
Which I thought was going to clean up all my issues. Like just a bit ago, had the car in park, running in the garage, and the car just stalls, then I goto start it, and all the errors I have pics of in this thread pop up again!
Discussion Starter #5
Well, my ProTool Bluetooth came in. Just replaced battery and reset all codes. Ran the car for awhile, all is well, then I park it and goto gym, when I come out, same issues when I started the car before I even put it in drive.
Screens of codes attached.
Looks like Crankshaft sensor failure.
Codes:
51A6
2A94
Found a few threads confirming:
https://www.e90post.com/forums/showthread.php?t=993063
https://www.n54tech.com/forums/showthread.php?t=49080
Opinions welcome. Ordering the part now...
1 - 5 of 5 Posts
