ISTA + DOWNLOAD LINK and ONE CLICK INSTALLER
42795 Views 85 Replies 74 Participants Last post by  jsBMWn63
Im sure you could find these for free somewhere but i just paid for it. ISTA + with one click installer so its easy to get setup. ive been having issues getting it to connect to my car but i was trying on an e91 so not sure if that is the reason why. I will try it on f series next week and see if i have any luck
You can download the BMW folder from the link below, please copy and paste this into your browser url. Please disable smartscreen as on some browsers this is enable by default and will prevent you from downloading this file).
IMPORTANT: AS SOON AS YOU COPY AND PASTE THE FULL LINK (ends in 7.z INTO YOUR BROWSER URL YOU WILL BE PROMPTED WITH A DOWNLOAD OPTION. 95% of users just require ISTA+ for diagnostics if you require ISTA-P then this requires and additional 60Gb of Harddisk space but is only required for programming.
ISTA+ (ISTA-D) – BMW Diagnostics (20gb Download) – For Diagnostics on E-Series & Diagnostics and Programming on F Series
www.xpcc.co.uk/2111/ISTA_4.32.1.7z
ISTA-P – BMW Diagnostics (27Gb Download) – Optional – For Programming on E-Series
www.xpcc.co.uk/2111/BMW.7z
Upon downloading, use 7zip (download for free from: Download) to extract the archive file and the remaining files will unzip automatically for each of the three downloads. Once download and extracted read the installation instructions with the .pdf file contained and follow it through step by step.
  • Like
  • Love
Reactions: 5
1 - 20 of 86 Posts
ISTA-D working on E serie diagnose only so you will need dcan cable and right setup in patched ediabas and settings in ISTA. For F serie and up you can use enet again diferent settings in ediabas and ISTA
Okay I tried e series with e net cable so maybe that's why. For f series with enet I change ediabas setting to enet and select enet local area connection?
Yes that is fine for f serie. For e serie need litle bit more setup and other cable. You can install 4.32.15 ista together with new sdp and blp. Problem you can have it just with brand new car some of ABL will not be there because off old app.
Why are these files so much smaller than the Other D and P I was provided? I'm looking for a one click install as the files presented to me did not come with installation instructions and it seems all file packages have small nuanced differences in the steps required. Hoping this makes it easier rather than trying to piece together the install.
Also, do these require a paid for license?
no clue but this works without license. worked for me on my f series car
Well this seemed to work like a dream. Install was a few minutes and started up. If this connects to the car and works then way, way easier than all these others. Thanks a bunch!
  • Like
Reactions: 1
Just make sure you configure it correctly with the right type of adapter you're using
Well, Looks Good!!!! Installed and clicked on BMW Group ISTA icon and I got a ol' big smile ;) Now, I need to order K+DCAN Cable and I forgot .........order a solar car battery charger, I got a Parasitic Battery Drain!!! ;( and to make matters worse......Hell I finally got a working version of ISTA!!!!!!!!!! Right On !!!!!! 2023 WATCH OUT!!!!!!!!
  • Like
Reactions: 1
You can just leave the car running also while using it
is this cable ok for E series ? Amazon.co.uk
I've sucesfully installed the ISTA+ (ISTA-D) software BTW. Thanks mate!!
thanks
  • Like
Reactions: 1
Downloading it now, I'll let you all know if it works
  • Like
Reactions: 1
Regarding my last comment.
Everything is working fine and I'm using the cable from amazon too.
can anyone explain what modifications i need to make for using this on an e series car? i have the k + d can cable. Thanks
Could anyone tell me what version of ISTA-P is in the link?
Thanks so much for the links and all your brilliant post. LIVE SAVEUR!
Has this been safe to use? Anyone know this bimmerdiagnostic.com?
Thank you for the links! Software runs fine and I could reset service indicator for a F750GS motorcycle with an ENET interface. However, I have fault code B7F34E in the TM ECU. If I try to reset it, error "Ignition was not detected. Fault memory deletion cancelled. Switch on the ignition and repeat the operation." is given, and no fault reset is done. Ignition is on. I have also tried to start engine, to stop it and to switch both position for the ignition switch. Is there anything I can do to reset such fault memory?
THANK YOU
1 - 20 of 86 Posts
