Status
Not open for further replies.
261 - 280 of 553 Posts
Super Moderator
Good day Almaretto!
Could I get a copy of everything I would need to use ISTA/P for my E53 please? Would I need to use the ICOM A(2) for that? OR can I just use my K+D CAN cable I use to code the modules on my E39 and E53? I've been using NCS Expert and WinKFP for most things, but I think ISTA/P is better for one-stop programming...
Thanks so much and Happy Holidays!!
Cheers!!
If you want one-stop programming, you will want ICOM as K+DCAN is will not communicate over all connection protocols for each ECU. PM Sent.
Very good!!
Thanks so much for your time!!
Cheers!!
Super Moderator
Friendly Reminder for those Requesting Software - See Differences and Requirements
E-Series & R05x Mini:
  • Interface = K+DCAN Cable (OBDII to USB) or ICOM
  • ECU Data Files = SP-Daten
  • NCS Expert = Coding Software
  • WinKFP = Programming (Flashing) Software
  • EDIABAS = Low Level ECU Communication Software used by NCS Expert & WinKFP
Fxx- / Ixx- / Gxx-Series, Mini (F05x/F06x), & Rolls-Royce:
  • Interface = ENET Cable (OBDII to RJ45 Ethernet) or ICOM
  • ECU Data Files = PSdZData
  • E-Sys = Coding Software
  • E-Sys = Programming (Flashing) Software
ICOM
  • ICOM A: main interface
  • ICOM B: adapter for programming multimedia in E series
  • ICOM C: adapter for old BMW with round 20 pin diagnostic plug
  • ICOM D: adapter for motorcycles
Additional Dealership Level Software
  • ISTA+ (AKA Rheingold or ISTA-D)
    • DIAGNOSTICS for All Vehicles
    • PROGRAMMING for F/I/G/RR & MINI, but requires an ICOM
    • All Requests, should be directed Here
    • Additional Details: Beginner's Guide to BMW ISTA+
  • ISTA-P
    • PROGRAMMING traditionally for all chassis, but F-/I-/G-series phased out with 3.63.5 release (March 2018).
    • ICOM Recommended. An ICOM emulator with K+DCAN or ENET can be used, but will NOT communicate over all protocols to program every ECU.
    • Replacement ECU's must be NEW
  • MINIMUM REQUIREMENTS:
    • Windows 7-10 Computer
    • ISTA+: 22 GB Installation + > 2 GB free space to run (Diagnostics Only).
      • Additional 70 GB SDP & ICOM to program (Excludes E-series)
    • ISTA-P: 112 GB Installation
    • At least a processor with 2 cores and 2.2 GHz
    • At least 4 GB RAM
Super Moderator
Could I get the link for ISTA/P please?
Thanks in advance
Could you please send me the link too?
Thanks in advance!!
Can i get the link for ISTA/P as well please?
Me too please if possible
Could I also grab a link for ista P & emulator to download please?
Thanks in advance!
Hi, could I get the link for ISTA-P please?
PM's Sent
Status
