1 - 6 of 6 Posts
hello everyone hope everyone is having a good day...my question is im taking out the ivm does it come all the way up so i can unplug the bottom wires? can anyone give me a pointer? thanks in advance
It kind of depends on how well they were tucked in there. After pulling and replacing units in the box, I can get to the bottom plugs much easier. The first time in is typically a bitch because the loose wire is trapped under the other modules and the brackets. You may want to pull several modules out partially to get better access. Good luck.
Super Moderator
Stranger, where have you been hiding?
1 - 6 of 6 Posts
