1 - 7 of 7 Posts
looking for a jack that can reach the front center jack point, what is every1 using? and also and good jack stands out there that are actually compatible with the adapters that bmw uses?
Jack & Jack Stand Recommendations
I just used the standard issue harbor freight jack ya just need a few boards under the front tires depending on how low your stance is.
Forgot to mention harbor freight jack stands as well.
No need to spend top dollar if you are only down there during standard maintenance times.
I'm using the cheap Harbor Freight steel floor jack for around $80 or $90 it's a 3 ton. In retrospect I would go back and get the aluminum one since the steel is very heavy to lift.
1 - 7 of 7 Posts
