rumratt said:Yep. In the front end, there's that little circle. It's perfect, except for the minor detail that it gets bent funny after a while.
And in the rear, no one agrees whether you should use the diff, or the little metal hump right in front of the diff. I put a hockey puck on my jack and use the little metal hump. I was under the car looking at it and it looks pretty solidly connected... but who knows...
robg said:I"m thinking that if someone makes a good, solid bottle jack or scissor jack
BahnBaum said:I would personally never get underneath any car unless it was on jackstands, ramps or a lift.
Alex
rumratt said:Actually, I think that works.
robg said:Well-- I'd only use this for brake work where i'm not underneath the car and I stipulated that I'm looking for a jack that "locks" and I'd also put a wheel/tire underneath the car in case it did come crashing down.
But, if you can tell me how to get the car up on jackstands w/o jacking it from one of the front or rear center points that seem to bend, I really want to know...
One idea might be to jack it hight enough from the rear side jacking points to get a jack stand under the front jacking point, but I don't think that would work.
For work under 1 end of the car, i'll use ramps w/ jacks supporting the end of the car i'm not under.
rumratt said::dunno: I've seen several folks jack up the whole side of the car (from a jack point), to swap two tires at once. What's the issue?
I tried it on the E30 though, and the rear lifted rather than the side. :yikes:![]()
Kaz said:What's wrong with the center points that the rest of us use?
You could use the framerails further under the car if you don't want to jack on the usual part.
robg said:Well, it seems like no one really agrees on what center points to use, especially on 00+ cars. For every post that says "use such and such a point", there's another (generally frm a knowledgale person) that says "no, use this one", or "that part will bend, or break".
The framerails idea is interesting, and I think i've read another post that suggest it, but I'm not quite sure where this is. :dunno:
rumratt said:My 330 doesn't quite look like that underneath. The rear points don't seem to exist.
BahnBaum said:Look at the picture that Bren posted. The recommended jacking points on the front are the frame rails.
Alex
rumratt said:Ack. I wouldn't do that either. I thought he meant to planning to work on one wheel at a time. I could be wrong.
robg said:Correct- i'd just be doing this to change brakes, so I could deal w/ 1 corner at a time.
brave1heart said:On my '01 325i, I can jack up both corners on the same side just using the standard jacking point in the rear. I use that sometimes when I need to replace wheels in a hurry. My rhino ramps have been very helpful when I can do work that doesn't need the wheels to come off. When I replaced the ATF and diff fluids, I drove the rear onto the ramps, then jacked up the front one corner at a time using the standard support points and put the jack stands on the LCAs. I think I had to alternate between the front corners a couple of times to be able to place the jack stands as high as possible for optimal work room under the car. There really isn't that great a need to be able to lift all 4 corners that often but it would be convenient to be able to jack up both corners on one end with just 3 pumps. Short answer is, there aren't any safe points under the car to do that.
robg said:I kind of like this idea for when I need to work under 1 end of the car (the end supported by ramps).
http://www.bmw325i.net/raise_rear.shtml
robg said:Thanks! That sounds like a plan. But, I'd be a little worried about putting the stands under the LCAs. I thought those things were pretty fragile on our cars?
To drain the trans fluid, I guess I'd put hte front on ramps and rear on jacks.
I'd probably also put jackstands somehwere under the rear as a backup.
