Is Roomie's battery as old as the car :rofl:
If you are connecting the jumper cables the correct way, there should be NO problem.
NEVER connect directly to YOUR battery, but always connect Red Cable to B+ (positive) terminal under your hood after connecting other end of Red Cable to Roomie's dead battery positive terminal. Connect black cable to his negative, and then other end of black cable to your ground lug under the hood (with your engine running). Done this way, there should be NO difference from a switch or relay applying a new load to your vehicle's system.
To prevent something on your vehicle from being switched off due to extra load/draw, turn off Climate Control, radio & headlights before jumping.
One of you (preferably Roomie, or both jointly ;-) should invest $36 in a multimeter & battery charger. Perhaps an extension cord is needed as well:
https://www.harborfreight.com/7-function-digital-multimeter-90899.html
https://www.harborfreight.com/26-amp-612v-manual-charger-60322.html
If Roomie's battery won't hold a charge for at least 48 hours, try disconnecting the negative terminal after it has been run/charged, and see if it loses charge disconnected. If not, he has a parasitic battery drain with ignition off, which will do the same thing to a new battery. Check back on how to deal with that, if the case.
George
My roommates Ford Country Squire sedan has been needing an occasional jump-start from my vehicle ('07 328xi coupe). Is this practice likely to damage my battery or any other electronics? Please advise. Thanks.
