oh, I got a few PM's from people with the same q's, so here's my responses:
I've been getting a few PM's about thet shark fin, and what it's used for, so here's my response to those people...
You do not need to use the shark fin antenna or the bee antenna for that matter, it is complely optional, BUT if you use it with a cradle (with a compatabile phone), it offers much better reception, as you are using an external antenna instead of the small one on your cell phone.
Other notes:
The EISKITs and Advanced Autovations kit are essentially the same. They will both cost you about $650 for all the parts. (w/o the cradle).
Both kits, which use the BMW ULF as the brains of the unit allow 4 phones to be paired with the car.
I believe that EISKITS is coming out with a product called Argos in mid March that will offer similar functionality, but will be about $450...
Also, both kits APPEAR to be the BMW factory ULF kit, but also included are a few harness' and adapters to make the plugs line up for a pre-2002. I do not know if any modification is done to the ULF. I'd wonder if it would be possible to swap out the ULF as newer ones become available... If that were the case, one could essentially make their own kit from the parts department, buying the indiviaul components--well provided that they could find the adapter harnesses'
