1 - 20 of 25 Posts
FS: Kenwood Amplifier & Rockford Fosgate Sub
I'm listing this for a friend who's selling a used Kenwood Power Amplifier with maximum power output @ 4ohms of 200W x 2 or 600W x 1 and a Rockford Fosgate 10" Punch P3. $150/OBO/cash. Local buyers only.
Specs for the AMP
Kenwood Power Amplifier: KAC - 728S
Output Power at 14.4V:
2 x 100W @ 4 ohms (0.08% THD)
2 x 150W @ 2 ohms (1 kHz - 0.8% THD)
1 x 300W @ 4 ohms bridged (1 kHz - 0.8% THD)
Freq. Response: 5Hz - 50kHz (+0,-1dB)
S/N Ratio: 100 dB
Current Consumption (1 kHz, 10% THD): 28A
Fuse: 2 x 20A
Dimensions: 11.8" x 8.7" x 2.2" (30cm x 22cm x 5.6cm)
Weight: 7.9 lb. (3.6 kg.)
Amplifier Type: Dual Channel
Bridgable: Bridgable
RMS Power at 4 Ohms 100 W x 2
RMS Power at 2 Ohms 150 W x 2
Frequency Response: 5 Hz - 50000 Hz
Signal to Noise Ratio: 100 dB
THD at Rated RMS Power: 0.08 %
Input Voltage: 11 volt
MOSFET Circuitry: Yes
3 Way Ready: Yes
Low Pass Filter
Specs for the sub
Size 10"
Impedance 4-Ohm x 2
Power Handling 400 Watts RMS
800 Watts Max
Voice Coil Diameter 2.5" aluminum
Motor Size 77 oz. double stacked
Speaker Connector Dual 8 AWG compression
SPL (1w/1m) 85 dB
Mounting Depth 5.9375 in.
(15.08 cm)
Weight 19.2 Lbs.
(8.7 Kg.)
1 - 20 of 25 Posts
