Are you sure the battery you put in was good? Also, if its a battery that came with the car, I dont believe you have to sync it with the car. It should just work if it has battery power.One of my original key fobs does not start or unlock doors. I bought a new key battery and tried to sync on steering column and still doesnt work. 2018 with 14,000mi. Is only path forward a trip to dealer?
thanks
Hd
If the battery in your other fob is still good, I would exchange batteries and see if your first fob now works - just be sure to insert the battery in the correct orientation, not reverse. If your fob still doesn't work, then there's a problem with the electronic board. If you've dropped the fob something might have jarred loose. Another thing you could try is to use your new battery in the second fob and see if that works or not - if it doesn't, then it's the battery that's a problem.One of my original key fobs does not start or unlock doors. I bought a new key battery and tried to sync on steering column and still doesnt work. 2018 with 14,000mi. Is only path forward a trip to dealer?
thanks
Hd
HdAnother thing you could try is to use your new battery in the second fob and see if that works or not - if it doesn't, then it's the battery that's a problem.
