I had same problem before and was able to fix it. First you need to do a quick troubleshooting. Lock all doors with your key. Then check if your gas door is still open. If so, that means the fuse in the trunk has blown.
The fuel door actuator shares the same electrical circuit as the key remote functions module (FZV, right c-pillar). If the fuel door is not functioning properly, then the circuit fuse is most probably blown.
The fuse is #53, 7.5 mA, and is located on the fuse bank in the trunk passenger side compartment; above battery. A fuse list is on the inside of the compartment door. It lists the fuses in physical order. #53 is the 8th fuse from the front and is designated ***8220;Central Locking System***8221;. Pull out the fuse and look closely at it. You***8217;ll find the center of the wire to be missing (burned). Good luck.
