I have a 2006 X3 3ltr Diesel.
Only when it is driven from cold it will make a knocking noise when turning for the first couple of corners and then go away for the rest of the day.
As soon as the wheel is straightened the noise goes. It is worse when turning left.
To explain the noise it sounds like a big end noise.
I recently changed the transfer case fluid and had the underside checked out and had new suspension and lower control arms fitted. There was no metal to speak of in the transfer case oil, just dirty.
I can't seem to find anything on the net that would relate to this, plenty of other clicking noises etc but none like this.
