1 - 3 of 3 Posts
I'd prefer not to lower my car as I fear it will scrape going into my driveway. Is there any significant performance-based reasoned to ditch the standard ZSP shocks if I go with the FSDs?
gashlycrumb
Springs probably last forever so if you like the drop as-is just replace the shocks/struts. Not sure if you'll get better handling/ride with a 'tuned' setup like the Koni FSD/Eibach kit, since when you buy the Konis separately presumably they're tuned to stock springs. When you're down there you might want to upgrade sways.
Discussion Starter · #3 ·
Thanks! I'm considering sways but since the rear is such a significant install job I thought I would wait.
Obviously, I meant to say stock springs with FSD in that last sentece
1 - 3 of 3 Posts
