1 - 4 of 4 Posts
· Natural Born Beamer
hey guys hope someone can help me - a week ago i had a whistling coming from the valve cover - I changed out the valve cover gaskets
11127582245 - N52 valve cover gasket set
11127552280 - N52 eccentric shaft sensor seal
11127559699 - N52 Valvetronic gasket
whistle went away - couple of day I saw smoke popped hood saw oil coming from cap that covers the orange diaphragm- saw this post
http://www.bimmerfest.com/forums/showthread.php?t=825981
so I changed out diaphragm cap- problem fix no more leak - then smoke again popped hood now leak coming from oil filler cap - saw that there was a up graded cap for the N52 so I bought it but no luck still leaking & when driving long time i open up cap a large pocket of air burst out -
I don't have dip stick Thought maybe computer might be reading oil level wrong I might have to much oil so i drained out oil & applied 6 quarts of full systematic 5w30- but still leak & large pocket of air burst out- its like its reverse in stead of vacuum it pushing air flow
07 X3M 3.0si
· Registered
slight vacuum at oil filler cap
>when finished with the repairs double check you have just a slight vacuum at the oil filler cap....put your palm over the hole .....it should just barely suck .....BUT ....there is a fault if it sucks big time or blows positive pressure
>did your diaphragm setup use a spring ????? ....if so ...is the spring mounted OK ?????
>some valve covers have return ports for the oil to drain back from the CCV setup ....are yours plugged ?????
Discussion Starter · #3 ·
thanks bro for reply
yes the had a spring we did attached it back - but yea the problem with the burst out of the filler cap did happen right after the replacement of diaphragm cap may be something went wrong -
ive been researching this it looks like blowby when in stead of vacuum there air flow
have you heard certech gels-
· Registered
retrace you job steps
>couldn't understand your wording about certech gels- .....but ....best go back a few steps and double check your diaphragm/installation job....also the spring orientation .....also ....is it the correct diaphragm ?????
1 - 4 of 4 Posts
