I'm an avid autocrosser. I've got a set of R-compound tires on a separate set of rims that I haul down to the autocross site with me. Believe it or not, the performance package doesn't have enough negative camber (stock) to use the INSIDE of the rims I have. At this rate, I would have corded the outside of the tires while the insides had never even touched the ground (the tires are quite rounded at the edges).
I have 3 autocrosses on these tires so far. I had my local shop flip the tires around on the rims.
I also had them install a set of SPC camber plates. These are the same ones the UUC Motorwerks resells:
This will allow me to jack the car up and increase the amount of negative camber at least another degree (probably closer to two) for autocrossing, and quickly change it back to my preferred street setting.
