1 - 4 of 4 Posts
The Canadian Prick.
Okay, I have a persistent leak that pools water in my interior lights. It leaks during car washes with high pressure, or even during a decent rain. (Overhead and map lights). I don't know if the water is coming in from my sunroof or the top of my windshield.
Does anone have any experience with which is likely to leak more on these cars? (Aside from the obvious assumption that the sunroof has moving parts so...)
Oh, the reason I'm not simply assuming the sunroof myself is that the windshield has been replaced.
Thanks folks.
The Canadian Prick.
Discussion Starter · #2 ·
No one has ever had their sunroof or windshield leak? :dunno:
Banned
Yes of course. You are relatively lucky. Most times you have to trace a leak up from the floor. You have already isolated yours. Sunroof is most likely culprit. You would need obvious windshield seal damage to cause a leak up top. Check the sunroof drains. One hole on each side at the front of the sunroof tracks. Clean and lube everything.
The Canadian Prick.
Discussion Starter · #4 ·
Thank you Lanc3r!
1 - 4 of 4 Posts
