1 - 5 of 5 Posts
2006 530xi 6 MT
Hello everyone! I found a little hole by a cable connected to the brakes. Does anyone know what this is called ? I have brake fluid coming out of here
"cable connected to the brakes"
That's the brake line. That part of the brake line is flexible. You need to replace the brake line there and bleed the system.
You may want to do that ASAP. If that hose cannot hold pressure, you will lose the functionality of that brake, or perhaps more.
Just did both my rear ones. One was leaking. I think the part was $19/side and took less than an hour to do both
2006 530xi 6 MT
torreaorlando27 needs to take the car in. While this job isn't especially hard or complicated, it isn't one for an inexperienced DIY.
1 - 5 of 5 Posts
