So.....I have a 2000 528i, E39, 180K miles, and My mechanic said yesterday I have a leaking fuel injector on cylinder 6. He Wasn't specific about the leak, not sure if its O-ring, the body of the injector or the top or bottom of it is leaking. (YES, I should have asked, but pretty upset with the list of things gone wrong....wanted go home haha :thumbdwn
Heres a list of problems right now:
-Valve seal is leaking (right onto my crank sensor, causing a misfire in cylinder 3?)
-Oil filter seal leaking (seeping)
-Power steering reservoir is leaking (seeping)
-BOTH crank sensors need replacement
-Leaking injector on cyl 6
-Needs a replacement spark plug on either cyl 3, or 6
-Possible fuel leaking down through cylinder (or oil)
At this point my car is not operable, clearly i know when to be safe....so my questions are:
1) What fixes need to be done first? and in what order? I know the injector is most important, as that could cause the most damage. I'm having it towed this week to my shop, no driving!
2) I've read that replacing all injectors is ideal, but that's an expensive fix I'm unable to accommodate right now. So, Is replacing just one okay? or is that going to make wear and tear uneven or cause another error or problem? I intend to keep this bimmer for awhile, so i know replacing them is my best bet.
3) The crank sensors, are they easy to replace myself? or should I just have the shop do it while they're replacing the injector and spark plug?
4) Anybody have an estimate on what it costs to have one injector done vs. all 6?
LAST PROBLEM: This is clearly a related issue, but maybe someone can help with my specific problem instead of searching the forums (as i DO, please don't respond telling me to look around, i HAVE, but would like specific answers if possible) :thumbup:
-On first start-up of day, the idle will drop in intervals, every 2-3 seconds, a small dip in rpm that sort of feels like it wanting to stall. Does that till its at operating temperature and then its gone, probably exists while I'm idling at a stop light but much less noticeable.
Anyways, if anybody has some answers to these questions, that'd be nice. my bmw mechanic will be looking at it this week, i'll be posting the solutions to all these problems as it goes along and posting them on the appropriate forums.
THANKS!
THANKS!
