1 - 3 of 3 Posts
My 2001 330Ci is leaking windshield washer fluid really fast. I will fill it and it's empty within a couple days. Does anyone know if this is a common problem and/or if it's an easy fix?
Vince
It could be the o-ring around the washer pump. I had that happen on one of mine before. Super easy fix if that's where the leak is. You just pull up on the washer motor to remove it from the reservoir, remove and replace the o-ring, put the washer motor back in, and refill the reservoir.
1 - 3 of 3 Posts
