1 - 9 of 9 Posts
Hello Beemer folks. I'm new to this forum and I have an issue.
My left head light has gone out. I replaced the bulb twice and still won't come on.
I have a 2004 330CI 6 sp coupe
Has anyone had this issue?
It's Bimmer, not BEEEEMER
I had the same issue. Replaced bulb and no affect. So replaced the ballast and all fixed. I have xenons.
Welcome to Bimmerfest!
If you have Xenon headlights, I would recommend exchanging the ballasts between the left and right headlights. Does the problem follow? If so, replace the bad component. As stated above, also check the wiring insulation.
:drive:
In the USA BMWs are called "bimmers."
Unless it's a motorcycle and then it's a beeeemer. :). Cars are Bimmers. Like Marco said.
1 - 9 of 9 Posts
