1 - 5 of 5 Posts
My left signal light on 2001 330cic is either burned out or has a short.
Has a changed the bulb? How do I gane access to the bulb and socket? Do I need to remove the entire light assemble?
Green...
If your left turn signal is flashing at a quicker rate, then it means the bulb is burned out and it needs to be replaced. Simply open the hood and reach in behind the light assembly on the driver's side and remove the plug-in for the turn signal by twisting it and removing it. Replace the light bulb and reconnect. You can buy the bulbs at any Kragen's or Autozone store near you.
Hope this helps!
1 - 5 of 5 Posts
