1 - 9 of 9 Posts
What's the life of 17" RFTs? I know the best answer is "it depends" but in general:)
You have 17's, so you'll have a better chance of not getting bubbles from potholes before end of life. Problem is life expectency is still short when compared to regular tires. I would guess maybe 20,000 if you drive combination city/highway. More if most of your driving is highway, less if city. My suggestion would be to make sure you've setup a tire fund just in case.
I have a 528i with 14,600 miles on it so far. It came with Eagle LS/2 ROF and the front tires have 8/32 tread depth, the rears have 7/32. I don't know what they started out as, so I can't tell you how much more life they have. I tend to drive fairly gently most of the time with an occasional sporty run every once in a while. So far, I have been happy with these tires as they seem to grip the road fairly well on turns and are not loud or too harsh a ride. Of course, the ride should be smoother than the 18 or 19 inch tires since they have more sidewall height.
Premium Member
2018 540i MSport
The RFT's on my '08 335i were at 42K miles when I sold it, and still had about 5/32" tread -- probably translates to 10K more miles. I had non-staggered M+S 17" and I rotated them at 8000 mile intervals when having the oil changes performed. I expect the 18" RFT's on my F10 535i to wear comparably.
Premium Member
2018 540i MSport
1 - 9 of 9 Posts
