1 - 6 of 6 Posts
I have the lightbulb warning showing in the instrument dash cluster. I've checked all of the exterior lights, and I can't find a failure. Every light seems to work.
Does anyone know where the sensor for lights is located?
99% chance it***8217;s a bulb.
Most likely culprits
1. On of the rear brake lights. Our cars have progressive rear brake lights. During emergency braking a secondary brighter set of lights light up. If one of the regular brake lights goes out the respective one of these will turn on instead. You need a second person to check if your brake lights are out.
2. Headlight halo rings.
99% chance it's a bulb.
#1. It's always #1
If you are by yourself, find a plate glass store window that you can see the back of the car in. Normal brake bulbs are in the fender. The "force"/secondary brake lights are in the hatch
Anti-Hack
^Easier to just quickly unplug the outboard brake lights and have someone hit the brakes. The inner bulbs take over in the event of a failure of the outboard lights.
Check both license plate bulbs (also a common failure, and one of the most common pull-over causes by the police).
Nuclear engineer
1 - 6 of 6 Posts
