1 - 4 of 4 Posts
· Registered
Hi all,
I was trying to retrofit the cruise control in my e70. I have added VO 544 and fa write CAS and FRM. Then coded each modules. The EHB3 is the only module that throw an error message but I recoded it again and worked fine.
When I drive the car the screen says 'faulty in drive'. The car is stuck in 3rdt gear and won't shift anymore. This all started after coding via ncsexpert.
I check the error code in inpa and the EGS has the CF33 error. I followed this guide http://wiki.bavariantechnic.com/index.php?title=Transmission_Fault_Code_CF33 but still no luck.
https://ibb.co/hcnRUm
Appreciate any response :(
· Registered
Discussion Starter · #2 ·
Problem solved. I clear the adaptation using ISTA-D. Waited around 30-secs until the car goes into sleep. Deleted the error while the car is off.
Car is back to life. I didn't know that there are errors that should be deleted while car is off. I always thought that ignition has to be turned on.
· Registered
Hi mate I no it was some time ago do you have instructions on how you did it I have insta + and cable all working mine is doing same thing driving me mad can't clear code cf33
· Registered
hi friend, i have the same problem,when i change the ecu map, car stuck in 3gear and dont change next and i have same fault code. If i delete adaptation with ista d. I must driving 70km for educate transmission?
1 - 4 of 4 Posts
