If you're just not happy with your car's throttle response and acceleration anymore, it's not time to go out and do big upgrades or buy a new car. It's time to fix the problem, and the automotive chemical experts at Liqui Moly have a high-tech fuel additive called Speed Tec Gasoline that could be exactly what your right foot ordered.
Liqui Moly Speed Tec Gasoline is one of the company's specially designed automotive chemicals. Pour a bottle into your gas tank and you can expect improved part-throttle engine response and faster acceleration at moderate throttle openings. In other words, it's designed to make your engine feel better in the ways you most often use it.
When you drive, it's not full throttle you're using every time you want to go faster. It's usually part throttle, at least unless your engine is underperforming.
A quick jab of the accelerator to get out of a blind spot on the highway. Maybe a few moments spent accelerating for an on-ramp. That's when you want maximum responsiveness from your car and it's when you'll notice that extra shove. It's also where Speed Tec delivers.
The scientists at Liqui Moly have painstakingly developed a special blend of chemicals to enhance your car's fuel. A proprietary mix of modern additives work to optimize fuel atomization and combustion.
What does "optimized fuel atomization" mean? It means smaller fuel droplets in your combustion chamber and that leads to more efficient burning of the injected fuel and to optimized combustion, which gives you more performance. Helping to improve acceleration and improve throttle response when you can feel it the most.
Speed Tec Gasoline from Liqui Moly is suitable to be used in any two or four-stroke gas engine. It can be used to improve throttle response in GDI and port-injected engines, turbocharged as well as naturally aspirated engines.
One bottle is enough for 7 to 20 gallons of gasoline, and for optimal results, it should be used with every fill up. Speed Tec Gasoline can also help your engine start-up better and run more quietly and smoothly thanks to improved fuel atomization.
Liqui Moly Speed Tec does more than just improve combustion. It can clean your entire fuel injection system, helping your engine run more efficiently and more smoothly even when you're not accelerating.
Liqui Moly Speed Tec Gasoline has no organometallic compounds. Those are old-style fuel additives that are often still used but can be seriously harmful and toxic to people. Speed Tec's cutting-edge formula is ideal for vehicles with catalytic converters and is safe for use in vehicles with pollution-trapping exhaust particulate filters.
For nearly 70 years, Liqui Moly has been producing motor oils and additives. The company's German research and development has lead to top-quality products and made the company the most popular brand in the reader’s polls in many German trade journals, winning countless awards for its automotive products.
