The 2 symptons together make it sound as if there is a blown head gasket but it is probably so slight that it seals itself within the first minute of running and will almost never shop up on a block test, that's the test that [email protected] is describing . What I have had to do in cases where I suspect this is to have the customer leave the car overnight so I can pressurize the cooling system overnight and have the engine cool down. Next all the spark plugs are removed and then you can look into the cylinders and see which one has coolant in it.
