Color change is not a noted issue with aging LED.I can tell any difference in these pictures from L to R. I don't see the yellow. Are these Xenons? or LED's? What year car?
LED not HIDFlicker is indication HID is failing, trying to run on high voltage from the igniter rather than high voltage from the ballast.
it’s hard to show on the pic, if you look on the ground you will notice it better.I can tell any difference in these pictures from L to R. I don't see the yellow. Are these Xenons? or LED's? What year car?
I thought I had LED not HIDYou have HID (Xenon) bulbs. As these age, they will change color, usually turning a pinkish/yellowish color. just replace the bulbs (both sides).
This is what I have."I thought I had LED not HID"
How many switches on the end of your turn signal stalk? (One equals HID, two equals LED.)
This?That is your light switch. Look at the end of your your TURN SIGNAL stalk.
