Hello all, I come asking for your guidance again. I'm parting out my 1994 530i manual. I've pulled the differential and trying to determine if it's an LSD or an open diff. It should be easy, but I'm getting conflicting information. According to realoem.com, the part number is 33101213880, and I have an open 3.07 or 3.15 (depending on what website I check). However, I'm looking at the diff now... When I turn the input shaft (where the driveshaft bolts to the diff), only the right output shaft turns. When I turn the right output shaft, the input shaft turns, and lastly, when I turn the left output shaft, the right output shaft turns in the same direction (and also the input shaft turns). This clues me into an LSD, but then how do I figure out what ratio? The tag is completely rusted and illegible by the way. Any input (heh) is appreciated!
Sent from my ADR6410LVW using BimmerApp mobile app
