Its a 2000 E39 M5, all stock except a Turner Motorsport tune.
I'm getting some pretty strange and random clutch feedback on my '00 M5. So on a normal day, the clutch grabs fine cold and hot with maybe some slight drag when shifting fast at WOT. Recently, it's been doing some weird stuff.
One night I was taking off full throttle from a stoplight (Car fully warmed up), and when I shifted into second, I was immediately banging off the rev limiter as the clutch didn't seem to grab, however the pedal didn't seem to return all the way either. Smelled a little bit of clutch too. 15 min later it was grabbing fine again.
However, this issue is becoming much more common. Leaving work the other day (Car is cold), I merged onto the freeway full throttle in 3rd gear when the clutch started to slip pretty bad at around 4K. Of course I let off, and up shifted. After a few miles I tried to repeat the problem to see if the clutch was spanked. pulled into the slow lane, dropped her in 3rd and hit the gas at 4-4.5K. Clutch grabbed fine this time and didn't slip... Wtf?
Tonight I took the car out to get food, and tested the issue. Did a mean pull with some considerable wheel spin shifting to 2nd. I put it in 3rd again and hit the gas, and stood on it. It slipped to 4k, stayed there, grabbed again and the car accelerated. Super weird. It's like taking the clutch out super slow, slips at first, but then starts to grab and you go.
In general, the grab point of the clutch seems to be about 5/8 to release, and has a bit of a gritty feeling when operating. Pedal pressure seems heavy, MUCH more so than the E90 M3 I test drove the other day. I HOPE its not the clutch itself, as with labor and parts can be over $2K, but I don't think we can rule out hydraulics either. The master cylinder doesnt appear to be leaking, but I cant tell if the slave is, as the diaphragm is located inside the trans. perhaps one of the cylinders are damaged not allowing the clutch fork to return all the way?
