1 - 5 of 5 Posts
cru$h dem
I'm looking to buy a m5 steering wheel and I wanna knw if it would fit my 2001 525i. Is it a ez change over and which one should I get. I'm getting one for $350 is that a deal or can I get beteer prices thanks :)
Seek to understand,^Value
I have no idea but this topic has been discussed a lot so why not just do a quick /steering wheel(F3) in the VERY best of E39 Links and start from there?
See the part I highlighted in red for you to find quickly ...
- What to do when both your automatic steering wheel tilt and manual & automatic driver seat control fails (1) (2) (3) (4) (5) (6) (7) (8) & related automatic steering wheel tilt details (1) (2) (3) & what to do if your steering wheel & key cylinder locks in place (1) & signs of a failing ignition switch (1) or ring antenna (1) & the BMW TIS for when the ignition switch spins but does not engage (1) & rebuilding a failed ignition switch (0) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) & how to test your BMW E39 DSC steering wheel sensors (0) (1) (2) (3) (4) (5) & how to retrofit to a 3-spoke M-Sport steering wheel (1) (2) (3) (4) & heated steering wheel retrofits (1) & updating the life of an old steering wheel (1) & where to buy the BMW steering wheel roundel (1) (2) (3) (4) (5).
It depends which year the M5 is. If it is a 2001-2003, it should fit your car with no problem.
Brevity= the soul of wit
You need to look at production date rather than marketing year. I believe the date began in 04/99 for all dual stage airbags and the wheels. This would include the 2000 model year in the US. If the M5 wheel and airbag you're putting into your 2001 E39 was manufactured after this date (most US versions were), you'll be just fine.
1 - 5 of 5 Posts
