1 - 6 of 6 Posts
HELP!! i just joined this site in hopes of solving my problem, i have a 95 530i and it wont keep the drive belt tension, i just shelled out 90 dollars for a new tensioner spring and i bought new belts and its still loose and im at my wits end ripping my hair out, PLEASE someone help
Banned
Remove the belt, hold each pulley, idler bearing and tensioner firmly, wiggle it. If they do not wobble even slightky, and if they each rotate in a single plane, then you either have an overdrive pulley somewhere but a stock belt, or you were sold the wrong belt (the old one on your car may have been the wrong length as well).
Goto realoem.com, put in the last 7 digits of your vin.number, drill down the parts diagrams to the exact part number for the belt and recheck.
In any case, doublecheck the length of the new belt using a tape measure. The numbers stamped on the belt in white refer to its length.in millimeters.
Resident e34 Racer
I create the tension with a wrench, and lock it in with tightening a bolt...
545i pilot
Still?
1 - 6 of 6 Posts
