1 - 2 of 2 Posts
Banned
Hey all. Just had a couple of questions to ask. I have a complete 1996 m62b44 aus spec engine and loom here. My problem is finding wiring pin outs for it all. I want to work out what all the connectors and relays are for on the dme side of the loom. I can understand the white 12 pin connector has the black/yellow starter wires and red/white ignition wire. So I can only guess that this is the equivalent of the E30s c101 connector. But would like to know/ see wiring diagrams or if anyone knows what these connectors are for. I***8217;m having a bit of trouble. I***8217;m new too the obd11 system (and will need to learn more about it). The furthest i have gone is Motronic 1.3 before and have now jumped into something a bit more hectic. This is going into an l-jet E30 btw which I have converted to Motronic. And yes I could go obd1 with the m60 loom but wanted to give this a shot as I***8217;m keen for the challenge and have already sussed an ews deleted ecu. Regards, William.
Under the lift arms
you need the Bentley manual set for the e30 and the e39 *i have both sets
everything you need is in there
that's how i do it when i do a engine swap like this
where are you located?
1 - 2 of 2 Posts
